>> Jump to guide's index PDF version v6
PDF version v5
I - Insert your files into software (drag and drop or use the green cross button to browse your file(s).)
b) Optional: if you click on the titleset, the preview window will show on the right: you can check the video by clicking on the "play" icon in the middle of the screen. The tabs under this preview lead to most available editing options. More about these options below under 'Overview of editing function in tabs'
II - Insert a blank DVD if you wish to burn your conversion straight to DVD
III - Press "Convert".
You're all set!
 Menu
> Index of Complete guide
Editing tabs under the preview window *Any changes made here will affect the titleset selected in the treeview, showing in the preview window.
If you want change settings that will apply to all your titlesets and/or all your future conversions in ConvertXtoDVD you should make these in the Default Settings, in the top menu of ConvertXtoDVD.
